Before Top Dead Center
Red Top Engine
Pittsburgh
Yes, you can use the kebab stick, or look through the crank timing port for the enlarged gap as someone slowly rotates the engine. If you use a rod, kebab stick, or whatever on the cylinder... be careful it doesn't get stuck. I had a telescopic rod get stuck using this technique and had to remove the head.
