Android integrated with factory screen
equilibrium
Couple of months back I was looking for an aftermarket Nav unit (I do not have the factory Nav) and found a company that provides entertainment solutions for different auto brands. For the Land Rover they have an aftermarket Nav unit and an android unit that can be integrated with the factory screen. I have ordered the android unit and installed it. The system is running on the factory screen without any change to the original unit features. It is using the NAV button to switch to the android screen.
Now I have a full functioning android system with a live data google maps. And I can install any Nav app available in the android market.
I have faced few issues with the touch calibration and sometimes the system get stuck but overall I am satisfied with the results.
It is a plug and play. The installation was easy (DIY) except for the gps antenna that had to be passed through the firewall to the engine bay. No need to cut anything so you can return back to the original setup without any damage.
Do you need to have it connected to an Android phone to pull map data from cell towers?
equilibrium
It is a standalone android system as if you are using an android tablet. If you want real time data you need to connect to the internet using wifi. It does not have to be an android phone you can connect to any wifi hotspot. Or you can download the maps and use it offline.
I am keeping a d-link usb LTE router connected to the usb port under the center armrest so I will always have connectivity.
Do you lose the "4x4" screen (assuming you had it before)?
Surfrider77
His first post said you don't lose factory screen / use. On the factory screen, you toggle back and forth from Android with the Nav button. (Assume you would prefer to use Google Maps or Waze from your Android screen anyway)
At least, that's how I understood him.
equilibrium
Exactly, this is what I mentioned in the first post. It seems my English was not good since I am From Saudi Arabia and I speak English as a second language.:hmmmm2:
You are the only one who got it here because you are living in the Middle East and you can understand when an Arabic person try to talk in English.:biggrin:
