Air-low sign?
motz
I recently bought a used 2006 LR3 V6 and I love it!
Can't wait to drive everyday and enjoy every moment of it.
I have a question.
Seems like my air pressure on my tires is low.
But I don't have a monitor or the screen with all the system in it.
All I have is the LCD screen on dashboard.
Would my LCD tell me if the air pressure is low?
or do you have to have navigation system?
I've also read some thread about backing up mirror dip.
I can't find the memory button on my electric chair.
V6 won't come with that function?
I've been reading mannual but it's kinda hard to figure out cuz
mostly the mannual is based on fully loaded V8 persion.
appriciate if you can help me!
Not sure about memory seat (but you may be right and they may be an option on some trims?), but the tire pressure monitoring system was not implemented on Land Rovers until later in MY06 production models here in North America. Unless you have a late build 2006, chances are your LR3 doesn't have TPMS. Check the valve stems on the wheels, if the stems are plastic/rubber you don't have the sensors.
motz
whoa...i just went my car to check the check the valve you told me to,
i found plastic pieces of lighter...i guess it exploded in my car
oh my!
anyway, i dont think mine has that function then.
i thought i would have it cuz when i press the "i" button, it will ask you
for mirror dip. what a tease!! ****...
thank you!
Trynian
The 06 V6 does not have the memory seats. Some have tire pressure monitors and some don't not sure when they started putting them in but I have seen some early 06 models sold in March 06 that did have it.
Not sure if it can be turned on, the sensors for the tires are about $70 each.
