A/C - Cold on the left, hot on the right
Bostonian
Gents - First I'll mention recently my car started 'farting' a lot more lately than it normally has from the area behind the glove boxes, as described in numerous threads . I can probably get in there to lubricate the offending bits.
So I'm not sure if the farting would have anything to do with the fact that I've noticed that the AC is blowing cold (sometimes, not always) on the driver's side, and warm on the passenger side. This tells me it probably (?) wouldn't be the compressor, or the system needing to be charged but some sort of temperature regulation. Previous summers it was ice cold. Any ideas to get me going in the right direction?
2beFree
Get the diagnostics on tje car. Most likely the stepper motor then on the driver'side if the aircon gas and plumbing is still fine
Bostonian
Bump. Any other ideas before I head in for a dreaded LR service call?
tlt
The farting is a air duct valve, and all you need to do is tell your shop/dealer it was farting, and that you want a new part, not the lubrication per the TSB. It will require tearing apart half the dash to change out, so it won't be cheap, but the part is inexpensive.
On the other, it would be worthwhile to have the vacuum lines checked, as well as the freon level.
Check, or have your cabin air filter checked, or changed, and inspect for water damage to the filter while they are at it.
Bostonian
Update: 4 o-rings replaced (juu500010, juu500030), freon recharged. $63 in parts, $345 in labor. Works like a charm.
2beFree
Hi there Bostonian
Where are the o-rings located? Glad you got sorted out.
Bostonian
hey 2beFree - I'm not sure of the anatomy of the a/c system, but the invoice describes the issue as 'a/c leak at rear a/c lines'. Wherever they are, it took a tech 3 hours to replace $25 worth of o-rings! Who says money can't buy happiness?
