97 Disco cruise control
surveyor
Hi everyone! Could someone out there PDF me a vacumn hose diagram for the cruise control on a 97 Discovery please ?
Thanks in advance!
Doug Lewis
[email protected]
Faison, NC
greg409
Can't supply PDF, but all hoses are hardware-store 1/4" rubber
Run from vacuum pump located behind/under driver's side headlight to "t" near brake booster, from "t" to rubber actuator @ throttle linkage, then thru' firewall to release switch @ brake pedal arm.
maybe 8' of hose?
Cruise ECU starts pump when button on dash is pushed, then set with steering wheel controls, brake pedal or switch release it.
luck,greg
  • joey
