95 D1 clutch pedal freeplay adjustment?
BeemerNut
I'm presently without my Rover mechanic's and parts department manuals.
Wanted to know if there is an adjustment for the clutch rod length or eccentric at the pedal allowing removing or adjusting excessive pedal movement before the fluid return port is closed off to apply pressure to the ***** cylinder? Wasted pedal travel resulting in less free clutch disc clearance, harder on the synchros as well shifting.
I just replaced the hose to the ***** cylinder and wanted to reduce this wasted pedal movement as the clutch disc starts to drag within 1 1/4 to 1 1/2" from the floor.
This has always been this way for years even with a complete new clutch assembly, ***** and master cylinder as well bled several times even with vacuum at the *****.
Where's Joey when I need him like years ago?
THX. .....~~=o&o>.....
Disco2TrailEdit4
