94, 95 to 96 era factory D1 rear sway bar & rear spring diameter measurements
BeemerNut
Anyone have a minute with a caliper and measure their Disco so I can establish what the factory stock coil springs and sway bar diameters are? Rear springs should be around 14 mm to 16 mm diameter range, rear sway bar my guess around the 23 mm range. Recently gifted a 94 D1 (bad engine) that has a 4" spring lift, sway bars missing at both ends. My 95 D1 I have aftermarket springs and sway bars hence nothing to compare off as the factory OEM springs and sway bars I gave away years ago. Thanks.......~~=o&o>.......
BeemerNut
Anyone?
I can't have the only 94 and 95 D1's on the face of this planet? BUMP......~~=o&o>.......
Disco2TrailEdit4
