2018 discovery salvage title
Dsmychynsky
Windber pa
New to land rover picked up a 2018 discovery on copart cannot get it to run? Only damage appears to be bumper cover and headlight?? Had a dead battery swapped it out... then stuck in valet mode. Curious if anyone has any ideas.. no codes when scanned with autel. Stumped
Dsmychynsky
Windber pa
Tbh1981
Ontario
Hard to guess without more info. As it's from Copart, the first thing I thought of is they keys. If you don't have the original key, the one you're using might not be coded properly.
If the airbags popped, that's a whole other issue.
remember5
I'm kind of confused, I thought Valet mode allows it to be driven but locks the storage box and back hatch. I assume it can be driven and it drives ok. Valet mode is turned off by entering the pass code on the screen. If you don't have a pass code that works then it's off to the dealer.
