jaguardoc504
- Joined
- Feb 10, 2014
- Posts
- 420
- Reaction score
- 100
Completed a front brake swap (June 2020) on my 2017 D5 HSE LUX, with 2016 RRS SVR Calipers and Power Stop Z36 Drilled/Slotted Rotors and pads
It is a direct swap. No need to remove the backing plate.
Simple as removing the old caliper, replace the crush washers and bolting back together with new pads and rotors.
The calipers are actually a little smaller than the factory D5/LR4 Calipers.
Prior to installing the calipers I had to use a 10mm wheel spacer for my 20" RRS wheels.
Here are a few pictures
