Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
The ground for the camera module is at the base of the driver's A pillar. The panel with the hood release has to be removed to access the ground. C2696 Right hand drive shown.
Thanks for the diagram, very helpful! Even when I disconnected the grounds circled below I still have 4ohms of resistance on my black wire from the cam mod connector which leads me to believe this is not the right one ? When I measure for resistance on these grounds circled, one is open and one has 5 ohms . Scary now I have airbag light, parking break fault and auto start/stop unavailable on my dash (I reconnected everything before turning the car back on). I may put my seat back in and drive it around keep getting low battery start car warnings when I'm working.
Update- I purchased a used camera module from eBay. Swapped it out and it immediately started working!! Couple days later, the thing dies again- same issue as before. Now, have I pooched 2 modules, or is there something else going on? Why did it work for a few days? Very frustrating for sure...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
