2013 Range Rover Sport suspension problem .
Jean-Marie
Whitehouse , Texas
Hi,
I have some issue with my 2013 R.R. Sport suspension, it seems to sway and become unstable when driving on the Highway at higher speeds.
Just checking if somebody has had the same problem and knows what is causing it .
Any help would be much appreciated.
Thanks, J-M
Jean-Marie
Whitehouse , Texas
I just checked and found no play , all rubber Bushings and Ball Joints are in very good condition.
I just test drove it again and noticed when you turn right to left car sways from side to side it acts like a car with bad shock absorbers .
Any idea if I have to change the 4 Struts ?
Vflo
Goshen, NY
Sounds like your struts are bad. Does your compressor still work? If so, you can just change the struts. At least that's what my mechanic tells me and I sort of trust him. I am changing mine this week. Just ordered struts. Hopefully it's the issue.
