2010 V8 serpentine and accessory belt replacement
Stuart Barnes
Los Angeles
Give this a go.
If you’re still unsure which way to undo the fan. It’s the same direction that the engine rotates. “Effectively” the engine tightens the fan coupling while turning.
Give this a go.
It's early morning so i may be asleep but it looks like he is going towards the left to remove?
Stuart Barnes
Los Angeles
That’s right. Just be careful and protect the radiator matrix when you remove the fan. The viscous coupling is heavier than it looks and it’s easy to damage the radiator fins.
txfromwi
I have these and they work on the 2013 V8 - left hand thread.
Watch which way you turn - depends on your year of course... NO supercharger it's a left hand thread, with supercharger it's a standard thread.
These are the tools as specified in the mechanics manual.
Amazon:​
DPTOOL Viscous Fan Clutch Wrench Compatible with Land Rover Discovery 3 4 Range Rover Sport 4.2 4.4 Petrol and 2.7 TDV6 303-1142 303-1143 303-1167 (Pack of 3)​
Here is a video I did - fan bit is at 57:32.
