2008 SC Lower Bushings
Cogs4x4
Anyone else have worn cracked worn Front Lower Bushings
- Know they're a common issue on LR3 and my past LR3 had them replaced @ 65/70k
- also the air struts on the front due to wear as well (leaking)
Mechanic noticed fronts were pretty bad - didn't really inspect rears..
Truck is ~95k and Dealership just inspected and said "Yup...they're bad you should replace them..." (that was paraphrased)
The just replaced the transmission as I purchased in in 2012 and immediately noticed it was pushing me at about 75% of my stops.
would stop and feel the trans push me like someone had rear-ended me..
typically would not be able to replicate at the dealership 150 Miles away - naturally
Was able to replicate in Las Vegas for that dealership and they only had one other known case of that noise and feeling on a 2010 SC (totally different truck) and the only fix they found was replacement of the transmission.
So long story short -
Are A-Arm Bushings covered under a CPO Land Rover Warranty?
Part of suspension and drive train & or electrical operation...
all trim pieces or non-safety equipment is not covered - like door/window seals
andyboy
"Should" be covered. I just had my swaybar bushings replaced and my warranty covered it. But I have a third party warranty. The air struts, however, probably isn't covered under warranty.
