Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
i had a 98 RR that had an inertia switch which triggers to shut off engine in an accident but only just realised that the 2004 does not have such. i discovered the fuel pump packed up. thanks
joey,
my rear right side has stopped rising. I have changed the air suspension, calibrated etc but no result. the air pump light keeps going off. the error message is Air Articulation Validity, what might be the prob. thanks
Have you checked your air-line that goes to that bag? In my case, I had the similar problem with the right rear side of my 04 RR-HSE. I had it calibrated and the shop did their job right and now my truck is porperly evened out front the front and rear. If your saying you had the air bag and sensor changed out already, my final be on the air-compressor, but it wouldnt make sense for the rest to work properly and the R rear continue to act up like that. Check your air-line if you haven't done so yet. Good luck man. Keep that Rover rovin...
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
