1999 Freelander
dodger
My Freelander is becoming a monster, its becoming very hot smelling and the top radiator hose is untouchable. The lower hose is fine to touch & the temp reading is normal. no air bubbles in the heater hoses.
The engine also cuts out after 30-40 miles as if their is no fuel, fuel pump is fine, if you give it a few mintues to cool off you can get a few more miles out of it before it happens again. Also the TC & ABS warning klights won't go out.
Any ideas as to what going on?
cheers dodger
Could be a bad water pump
symoth
jerking at rev 30-40 for freelander
u may need to change the crankshaft sensor.
Disco2TrailEdit4
