garylevine
- Joined
- Nov 6, 2010
- Posts
- 3
- Reaction score
- 0
Here is a good one. In the last two years, I have now had 4 radiators. My shop installed a used engine two years agos. When they did it, they claimed that the heater leaked into the passenger side. Not true as it worked fine before the used engine was installed. They bypassed the heater with a hose that was very short and crimped in the middle restricting the water flow. Now three radiators later, I was told that the water flow was restricted by another shop. I agree . My shop now disputes that and says that it would have overheated all the time. Question is, If the hose that was only about 10 inches long was crimped in the middle, could this restriction cause the overheat and could it be intermitent? Is there any other reason that would cause this problem. Thermostat was replaced awhile back too. Shop now blames the thermostat. They are good guys at the shop but this is absurd.
So, If you bypass the heater, and the hose is short and pinched, is that the most likely cause given that it is the only constant in the equation that is a factor in all radiators and overheats.
