Need Part Numbers Please - Differential Drain Plug and Transmission Heat Shield
txfromwi
Thanks!!
On my 2013 LR4:
Front Differential Drain Plug
There are 2 different plugs depending on the differential serial number, which then tracks to the VIN number
I have the Drain Plug Part Number for my actual VIN : that's the square 3/8" driver Part Number TYB5000110 - per Rover
I would like (for completeness) the part number for the drain plug that has the 8mm hex driver
I believe it to be TYB500080 - but I cannot prove it.
On the transmission - mine does not have a heat shield - (we bought it new) - and per Rover there is no transmission heat shield for the 2013
- but they have part numbers for the heat shield bracket and the heat shield bracket bolts for the 2013
- and the heat shield IS shown in the mechanics manual - keeping in mind the manual is technically 2009-2012
Is a heat shield from other model years going to fit? Which model year? And what is the part number?
Jimmy Brooks
Pasadena California
Thanks!!
On my 2013 LR4:
I think the heat shields only came on the LR3 Zf6 transmissions, I remember coming across this same thing in the workshop manual and researching it because mine too did not have a heat shield. I don't think any LR4's came with a transmission heat shield.
Rover Range
Texas
I've never seen an LR4 diff drain plug with the allen head.
Transfer cases have the allen type plugs.
