Diagnostic Tool for Discovery 5
RyanRR
Wisconsin
GAP Diagnostics IIDTool BT from Lucky8llc.com
The GAP tool has been invaluable to me with my LR4.
Clearing codes, changing suspension height, diagnosing issues, etc.. All for $525 or so. It'll pay for itself if you use it twice instead of going to the dealer for codes/diagnostics
gmfain
Update on resetting the service interval.
I was able to try out a iCarsoft LR3 Ver3.. It will not reset it. It can't do anything DEF related either.
Tech support is non existent. Pretty sure the email was from guangdong. I got three replies, of "We will look into it.".............. I asked one question. " Will it reset service reminder 2017 D5 TD6?"
Seemed to be a Yes or No question to me.
Don't waist your time or money.
gmfain
whammie
NJ
Try this one. https://www.amazon.com/gp/product/B07WDGY9Y2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Launch CRP909X it is another Chinese one, but I can confirm that it resets the Land Rover. I have a 2017 D5 TDI and it worked on mine where the hood/door open press both pedals did sh....t!
I can also confirm that it works to put the E-brake in service mode as well and retracts the e-motors so you can push the pistons in. The Daigun V model also works but is almost double the price.
gmfain
Update on dia tool. I have conformation the Launch crp909 works.
I have ordered it.
I will report back over the weekend.
DonC
The Woodlands, TX, US
It seems Disco 5 is limited support? Do you have Disco 5 experience with it to help share its current systems it works well with?
It is still in beta for the D5 (anything post 2017) right now. First thing that a user would need to do would is be on the Ver 3 of the device as the older ones will not work. Patrick does offer a trade in option to get the V3. I have been able to do a few things with it like reset adaptives. service reset, pull and clear codes, and suspensions options like set tight tolerance. Key programing has been an issue for me right now and I am trying to sort that out with Patricks help at Gap.
dimitricourmousis
