New (to me) 2012 LR4 5.0
M32H32IS
Texas
Hello,
Recently purchased a Baltic Blue 2012 with 155k miles and a fresh rebuilt engine. Runs nicely, the machine shop has experience with JLR & did a great job.
All coolant lines replaced with new JLR parts
Timing chain guides & tensioners replaced
Ceramic coated
Question: with the mileage, there’s a bit of front end slop. What’s the best resource for complete front end rebuild part?
LR4Slavo
Denver
Nice rig and welcome to the forum!
Check out Merriam LR out of Kansas. I found them to generally have the best prices for OEM parts, online ordering only and it's best to order everything at once to cut down on shipping costs.
ftillier
Portland, OR, USA
You might be tempted to replace the suspension bushings with polyurethane ones that will last much longer. Just know that they do stiffen the suspension and you will get more nvh in the cabin. It's a trade-off between comfort and longevity, and I wish I'd stuck with comfort personally.
Hello,
Ceramic coated
They rebuilt the engine and then you replaced the tensioners? Or was this done during the rebuild?
M32H32IS
Texas
Pulled & completely disassembled, balanced crank, new pistons & rods, machined block & heads. The works.
All new cooling system from radiator to water pump to hoses.
New belts
New injectors
Cleaned all parts that were reused.
ftillier
Portland, OR, USA
Had it overheated? If it hasn't been done already, you'll want to change the transfer case and differential oil (every 75k) and transmission oil (every 50k).
M32H32IS
Texas
It overheated when the rear crossover failed & it dumped coolant hence the machine work and complete overhaul.
Good call on the fluids. Anyone know where’s the best vendor to purchase from & what fluids are best to run?
ftillier
Portland, OR, USA
The rear differential fluid depends on whether you have the electronically locking vs open diff (hd package I believe). Fluids are a pain IMO, and I've found the independent mechanic's prices worthwhile personally. The tranny fluid requires you to fill with the engine running with the car level, something I couldn't do in my too small garage, so I had it done.
dimitricourmousis
