Repair and Preventative Question
chrisp
Someone decided to hit my taillight with who knows what in NYC the other day so I have a crack in my left rear light. Wondering if it’s something I should replace or just leave as is. Seems mainly cosmetic, but wondering if water intrusion will mess with the electrical system at all. Also are these easy enough to find second hand? I’ve seen a couple on EBay, but they’re not OEM. New ones seem to be around 5-6 hundred.
Other than that, I’m wondering if anyone here has undercoated? I’ve been interested in doing that, but I don’t want to do it every year as some places suggest. I was wondering about using farm supplement…I expect it would last quite a while but never used the product.
mmbirtcher
Grew up in Boston area. If I still lived up there or NYC area I’d look at a dry-ice chassis clean followed by a Waxoyl treatment. Luckily, I’m in St. Louis now where just keeping the underside clean is sufficient.
mm3846
LI, NY
I plan on doing it every year, I do it myself. Last year I used fluidlfilm, going to try out the new PB Blaster stuff this year.
chrisp
Ya I’ve read about the PB Blaster stuff…seems promising. I’ve used other PB blaster products for years on my older bikes. When you’re putting on the coating if there’s already rust do you just go over it?
mm3846
LI, NY
Yea, as long as it's not flaking off or badly corroded you can go right over it. If you want to do it "right" I'd pick up the Eastwood branded product of your choice (some are for painting right over some rust, or heavy rust, or for a frame after you "clean" the rust off) first, then use the lanolin coating after.
helge
