Help fitting Terrafirma rock sliders
Miguel T
mt view
Timbo
Long time lurker, first time poster.
I just installed a new set (from Craigslist) of Terra Firma sliders on my LR3.
I trimmed about 4" from the area were the air compressor line interferes with the inside of the slider (see picture )
let's see, yes on getting rid of yellow knobies, no on the black ones.
I sprayed some 3M wax on the sills/rockers though not needed.
I covered the holes inside the sliders, they used crappy duct tape.
No need for the nuts, just bolt and washers.
when installing loosen the clamps to the compressor lines, same on the AC lines on the other side, it will help with sliding that inside part.
On the compressor side I made the trim just aft of that hard clamp thingie holding both lines.
When I slid the slider (see what I did there) I pushed the compressor line under and then around over towards the back.
If you use a floor jack to position the slider under the sill, you can then mark and measure where to cut.
I went conservative, cause you can always cut more if needed, as it turned out first time did the trick.
As for integrity, use your own judgement, YMMV.
For my mostly, well basically stock LR3, my new trimmed Terra Firma sliders will do just fine.
Yes I wished they offered more protection, but it would take a lot of off roading for me to justify the money and weight penalty on a mostly mall crawler vehicle.
These things should do well for overlanding and light offroading, and hopefully will absorb any damage to sills/rockers.
HTH
Edit: added pict of sliders on car
mflecklr3
These look like the TerraFirma sliders. I didn't have the patience to watch the entire video but maybe they address the issue with the AC lines.
douglastic
I don't even see those sliders offered on their website
mflecklr3
yeah, I know the link to their site is broken but the sliders in the video sure look like the TF ones.
douglastic
I'm not so sure - the TF ones have their "M" logo stenciled into the side sill
I think the ones in the video are Britpart - no "M" cutout, and comes with the grip tape
Britpart DA7533
mflecklr3
I think you're right. The bolt holes and welds look the same but the metal that wraps around the sill is a different shape. Sorry for the bad info.
Miguel T
mt view
Having just installed a set I can say they are close to TF ones. The hardware looks nicer on the set of the vide. I like the countersunk washers.
Without the inside it looks like a much easier install, I don't know how much more integrity the inside wall adds on the Terra Firma set. Otherwise they look like close cousins.
