Transmission fault
Dyylh
2012 Range Rover sport has 52k miles on it, yesterday showed transmission fault when it was on 65 mph, after 15 mins drove, turned off the engine, turned on again, didn't show the message. Wants to know what is the problem. Contact the dealer for service, won't get into until next Tuesday. Please help. Thanks
joey
Have your battery tested, at any autoparts store. The odds are your battery is starting to show its age.
Dyylh
Should I go to dealer or any recommended auto shop in Quincy Massachusetts? Thanks
joey
Any autoparts place that will test your battery for free... dealer will charge you just to test. Get that out of the way first.
If the battery is starting to age, anyone can replace it. I like the dealership for many things but most times service cost hamper me from going there.
Dyylh
Hi Joey, did the battery check up, it showed 1/3 battery usage left, so is it the problem caused transmission fault, should I go to dealer to check it up too? Or just replace the battery? And what brand I should get.
joey
I would replace the battery, and brand isn't a huge factor anymore with batteries it is more just a preference like oil or tires... Just make sure the battery is of equal or larger CCA and matching vehicle requirements.
TeriM
