LR3 Roof Rack Opinion
samnt650
Reaching out to the forum, to see what people opinion between Voyager vs Baja roof rack? I plan to use the roof rack as
- viewing platform at NASCAR races
- roof top tent for camping
- spare tire / hi-lift jack during off-road
- off-road light mount
Yeap.. the rack is going to be abuse...
Hannibal USA. Not the size for the lr3 but the size for Disco 2. Nice flat slats for easiest hang out space but also light and strong for everything else.
pvangura
I just installed the standard Bajarack on my LR3, and so far I'm pretty happy with it. The build quality seems good, I'm able to walk around on it without much deflection in the rack, and it seems to have plenty of space for anything I could want to carry. It's also damn quiet, and still allows the sunroof to open. I'll be loading up the rover for a trip next week, so it should see it's first use then. I'll let you know if I notice anything negative.
...any interference with sunroof operation?
pvangura
What do you load on to your baja rack?
Charles,
Well, I haven't put anything on it yet. On my previous rack, I carried all sorts of things, including firewood, off road equipment (hi-lift jack & shovel), jerry cans, and luggage. My plan for the Bajarack is to use it for pretty much the same stuff. I've got a couple of decent sized Pelican cases that might end up riding up there for camping trips as well (leaves more room inside for the dogs!). I'm also thinking about carrying the spare tire on the forward portion of the rack during extended off-road trips. After suffering through unloading the truck in 100+ degree heat in the middle of the Utah desert just so I could change a tire, the roof carry option is looking pretty nice.
Paul
tlt
Maybe a few of those wanting the Baja could put together a group buy if we're not in a hurry. I can look into it if there is any interest.
4advtr
Just a little insight into the BajaRack. In my opinion they aren't very well suited for walking on. They are great for loading things onto but the psi from walking on the thinner cross support rails can cause them to bend. I have one on my D2 and used to own a shop where we sold tons of them. They are excellent racks other than this particular usage.
perkj
Utilizing a Bajarack as a viewing platform to walk/sit on, etc, the use of some chicken coup flooring from Farmtek works perfect to avoid the potential of bending mentioned above: http://www.farmtek.com/farm/supplie...01&langId=-1&division=FarmTek&productId=20251
I utilize those on my LR3 Bajarack for the times I want to use as a viewing platform.
BTW: walking on those thinner bars doesn't really bend them, you just see a little flex in them.
helge
