Hey Joey,
I fixed the problem. I guess there was overflow supply of fuel to the engine, si it was choking.
I happened to loosen the pipe which pump fuel back to the tank and had some fuel spilled out. Tightened it back and it started.
Thanks for your help anyways.
By the way I have another minor maybe major problem. When applying my brakes the brake lights go out, but when I let go the turn ON. I guess its a wiring problem.
Would you know if the procedure of getting it fixed is lenghty and if i can perform it by myself??
