Help needed with continued errors
jagonz
USA
Well everyone I’m here to see if the forum could help me out with my 2005 LR3 4.4l V8.
First are the dashboard warnings.
Second are the trouble codes read with the GAP IID Tool.
Third are all of the replacements I have completed within the last 4 weeks.
Fourth is what I have taken apart and cleaned.
Any help would be greatly appreciated and thanks for your time to read.
Dashboard Warnings:
Special Programs Off
Transmission Fault Limited Gears Available
Parking Brake Error
Trouble codes from the GAP IID tool:
Airbag
  • B0001-1B (AF) Driver's frontal stage 1 - deployment control - General electrical failure - circuit resistance above threshold
    ( on 16-04-2025 16:17:48 at 180370 mi )
  • B0002-1B (AF) Driver's frontal stage 2 - deployment control - General electrical failure - circuit resistance above threshold
Engine Petrol
  • P0102-00 (36) Mass or volume air flow circuit low input
Instrument Pack
  • U0164-87 (27) Lost communication with heating ventilation and air conditioning control module - Bus signal/message failure - missing a message
  • B1A00-46 (50) Control module - System internal failure - calibration/parameter memory failure
    - Test Not Completed
    - Test Not Completed This Monitoring Cycle
  • B1A75-92 (50) Fuel sender 1 circuit - Component failure - performance or incorrect operation
  • B1A76-92 (50) Fuel sender 2 circuit - Component failure - performance or incorrect operation
  • B1A78-64 (50) Front fog lamp circuit - Algorithm based failure - signal plausibility failure
  • B1A79-64 (50) Rear fog lamp circuit - Algorithm based failure - signal plausibility failure
  • B1A80-64 (50) Oil pressure circuit - Algorithm based failure - signal plausibility failure
  • B1A81-64 (50) Internal trip switch circuit - Algorithm based failure - signal plausibility failure
  • B1A82-64 (50) External trip switch circuit - Algorithm based failure - signal plausibility failure
  • B1A84-46 (50) Vehicle configuration data - System internal failure - calibration/parameter memory failure
  • B1A86-64 (50) Ignition status - Algorithm based failure - signal plausibility failure
  • B1A87-68 (50) Battery disconnection/electronic control unit reset - Algorithm based failure - event information
  • B1A00-17 (50) Control module - General electrical failure - circuit voltage above threshold
  • B1A00-16 (50) Control module - General electrical failure - circuit voltage below threshold
  • B1A88-49 (50) System timer - System internal failure - internal electronic failure
  • B1A00-4B (50) Control module - System internal failure - over temperature
  • B1A00-48 (50) Control module - System internal failure - supervision software failure
Steering Angle
  • U1A14-49 (50) CAN initialisation failure - System internal failure - internal electronic failure
  • C0051-64 (50) Steering wheel position sensor - Algorithm based failure - signal plausibility failure
  • U3002-62 (50) Vehicle identification number - Algorithm based failure - signal compare failure
Terrain Response
  • U0402-94 (27) Invalid data received from transmission control module - Component failure - unexpected operation
    ( on 16-04-2025 17:26:56 at 180370 mi )
    - Test Failed
    - Test Failed This Monitoring Cycle
    - Pending
    - Test Failed Since Last Clear
  • U0416-94 (27) Invalid data received from vehicle dynamics control module - Component failure - unexpected operation
    - Test Failed
    - Pending
  • U0421-94 (27) Invalid data received from ride level control module - Component failure - unexpected operation
    ( on 16-04-2025 17:27:03 at 180370 mi )
    - Test Failed
    - Pending
  • C1A02-94 (50) Rotary encoder stuck in the intermediate position - Component failure - unexpected operation
  • C1A01-96 (50) LED circuit - Component failure - internal failure
Transfer Case
  • P0903-00 (50) Clutch actuator - circuit high
  • P0902-00 (50) Clutch actuator - circuit low
  • P0900-00 (50) Clutch actuator - circuit/open
  • P173F-00 (50) Ignition key lock solenoid - circuit high
Transmission
  • U2023-86 (27) Control module network signal calibration data - Bus signal/message failure - signal is invalid
Replacements:
Brake light switch, FOMOCO, Jaguar
Alternator, Denso
Battery, Diehard
All taillight bulbs replaced, RoverParts.com
Transmission Fluid changed, ZF
Solenoids replaced, ZF
Transfer Case Fluid changed
Front and Rear Differential Fluid changed
Transfer Case Control Module, cleaned connector and it was corroded with green oxidation.
