Coolant Tank / Cap Question
M32H32IS
Texas
My original expansion tank developed a leak so I picked up a replacement off Rock Auto that included a cap.
Odd that the cap is rated 110kpa instead of 200 like the original. Should I swap caps?
I wonder if the tank can take that pressure? I would be getting a tank that runs (or can handle) the stock pressure required which is? 110 KPa is pretty much atmosphere.
M32H32IS
Texas
Been running original cap with 0 issues. Interesting enough, the system is no longer over pressurized at operating temp. No swollen hoses. No pressure the next morning.
I’m a bit concerned lol. It’s acting normal.
M32H32IS
Texas
It wasn’t leaking. Til it did. Threads failed on the aftermarket tank. Picking up a LR tank today - that one was terrible from a quality perspective. Couldn’t hold designated pressure hence the 110kpa cap.
M32H32IS
Texas
original made 192k miles. Cheapest aftermarket on Rock Auto lasted about 200 miles. Well, it may last 192k if I run their cap but no thanks. I’d like my coolant to be operating at the correct pressure.
greiswig
Supporting Member
Supporting Member
SW Washington
Maybe they were trying to make the cap a pressure fuse, and keep you from blowing out the plastic coolant pipes. :rolleyes:
