Hi guys,
A couple of weeks ago my LR3 2006 has started have intermittent fault and this is now steady (as soon as I turn the key):
1- The following amber fault lights are steady on: ABS, DSC/Traction and Brakes.
2- When I brake for a stop I hear an electrical signal in the engine bay around the ABS module and then I feal and hear the ABS kicking-in but this is bearly noticeable... This even if there are absolutly no reason for the ABS to kick-in...
Following those issues I did (in an attempt to fix the issue):
- Battery was tested perfectly fine
- Changed the brake switch for a new one
- Changed all (4x) brake lights for Land Rover new ones
- Tested the continuity of the brake pad wear seasor circuit at the cluster. all good.
- MASS air sensor is perfectly clean
- Tested almost all wire continuity of the ABS module (except HDC relays, Yaw sensor, ABS sensors, park-brake switch)
- Tested continuity of circuit between Cluster, ABS and Tranfer box control module
Due to those errors, the suspension eventually drops and suspension amber fault goes on, but I believe this is just a side effect. So for now I have removed fuse 26 to be able to drive at normal height...
I am now out of ideas... All this looks like related to the ABS or traction control units but I dont know how I can perform more tests...
Any ideas please??? Thanks!!
