Came across this while looking around for parts, have no affiliation with this, don't even have a 5.0 just letting y'all know.
Depends on how they're sealed, no?Two screwed together halves?
No thanks.
Weird… my front one never went bad (before it was replaced) it was the rear crossover that blew up with no warning.looks sketchy; if it were welded together that might be a better option. since the rear heat manifold rarely catastrophically fails just begins to leak, i would use oe plastic one. Now if they will make a front crossover out of aluminum for the 5.0 NA, that would be excellent.
Is the oem plastic one seamed in the same spot? A local shop uses the ones from RKXTwo screwed together halves?
No thanks.
