Do you think the tune actually improved your mpg, or is that what you were seeing before?
Ditto on this question. The trip computer claimed MPG is consistently around 5% higher than actual, despite entering the max allowed correction factor via Gap/IID tool. I track gallons added from the pump receipt, and write down the trip computer miles, to calculate actual MPG. Typically in the 15-16 range for our 2010 with V8 around town. Haven't made any long freeway trips without a trailer yet so I'm not sure what it will peak at with the cruise set at 85mph.Is this according to the computer, or based on manual recording of miles/gallons? ... Keeping track manually, I’ll only get 16 mpg if I’m all highway.
Are you driving it like you stole it?
also, did you upgrade the intercooler/charge air cooler pump as well or leave it stock?
I’m in a yes I want it / I don’t need it schizophrenic place with a tune right now
Stu.
I would say assertive driving; not ******* it but not out for a Sunday cruise. Only other mod is K&N replacement filters.
And I upgraded to a higher flow Bosch inter cooler pump.
Bosch 0392022010 Electric Water Pump, 1 Pack https://www.amazon.com/dp/B00BHGPZV...abc_2ZXPS1CTA0B1ARJQ5VEX?_encoding=UTF8&psc=1@Fuji4 do you have a link or anything to what you used? I'd be interested in doing this too
