Sorry some of you have such frustrating experiences but blaming the vehicle for brakes, tires and even batteries is kind of silly when the wear items are usually more about user error than the vehicle itself.
Brakes: I had two sets of rotors last almost 130,000 miles....yes.
Tires: selection of an appropriate tire for the weight and uses will yield similar results, I.E. over 60,000 miles on the first set of BFG AT KO.
Battery: A high quality unit such as Odyssey is in my lr3 for 10 years now with still near top % rating on load testing. When the factory battery was losing it's steam about 3-4 yrs in, I replaced it with an Odyssey 1750 I think. The house battery is a 2150. I also put one in the Audi but you have to have a proper charger that can work with these.
It's possible my lr3 has needed a water pump and/or alternator but there hasn't been so much that I've felt like it was beyond some level of reasonable frequency considering the vehicle as a whole.
However, I did spend about 5 years simply worrying about the air suspension potential for failure, then when it simply never failed, I finally gave up and relaxed
A note about tires and brakes:
Tires, you must keep in mind that this independent suspension design lends itself to wearing tires much faster on the inside edge, especially in the rear where camber is most extreme and even more-so if towing often.
Obviously one can rotate the 4 corners diagonally depending on tire design, however anyone with a larger than factory size should also have a full size spare. This 5th tire should absolutely be rotated into the mix each time for a few reasons:
1-so all 5 have similar wear in the event you have a flat near end of wear life you need to have similar sized tires on same axle.
2-using all 5 prolongs the time to replacement by 20% ! Consider that-you put off cost and hassle of dealing with buying new tires 20% longer.
3-when using all 5, you don't end up with an old tire upon replacement time. You also get the new model or can choose new version without any issues.
Brakes: My brakes last a VERY long time but I hear of people with much lighter weight lr3/4 burning through 2-3x faster..... it's not the brake parts..... it's the driver. Bet I'd pass all of them on the highway but they waste $1000's on brake parts thinking they don't have time to not brake hard at every stupid light LOL. These types should just drive a Toyota Highlander and quit complaining
