12/24V 120Vac 40LTR Portable Fridge / Freezer
tlt
12/24V 120Vac 40LTR Portable Snomaster Fridge / Freezer
There comes a point in time when you are tired of hauling ice, dealing with melted ice, and switch to a DC fridge. The problem is most are inefficient at best, or power hungry. This will solve all your problems. A rugged stainless steel unit designed to last a lifetime of continuous service. Everything you need is included, Transit bag, remote control and fridge.
This is a great size unit for bugging out, or for everyday use in your vehicle, camping, boating or events. Post SHTF this unit will provide safe reliable cooling for critical medicines, or keep your ICE for drinks. It will operate as a fridge or a freezer, just set the temperature and it will maintain it, regardless of the ambient outside temperature. It has an oversize compressor, so regardless of the outside temperature it will keep cold. Great to load your meat or fish from hunting or fhishing. I have run these type of units year after trouble free year. Never worry about rust with it's stainless steel construction. A free insulating transit bag is included to protect the unit, and provide additional insulation when out in the African Savanna or in the middle of the Utah desert. Run it at home on AC, if the power fails, the DC will automatically take over. Ideal size for a few days in the field. It's small enough to fit in your vehicle, and moved by one person.
Detailed item information
40 Litres 1.41 Cubic Feet is about a couple cases of beer) or $300.00 worth of meat.
Includes transit bag
Three Baskets
Digital remote Temperature Controller
Wireless Temperature and Battery Monitor
66 Watt Snomaster Compressor
5 year Warranty on Compressor and 1 year on Cabinet
12/24V DC 120AC volt internal power supply
Open Lid alarm
16mm polyurethane insulation 5/8"
Stainless steel cabinet
Stainless steel hinges, locks and handles
Temperature range -22 to 10 degrees -7.6F to 50F (unit will display F)
Internal LED Light
High speed operation 5 amps @ 12V
Low speed operation 2.5 amps @ 12V
Voltage cut out can be set between 10 and 11.5 volts @ 12v
600x420x520 (WXDXH) 23 5/8 x 16 17/32 x 20 15/32
fiveonetwosixnineeightsixonesixnine
$1200.00 Price includes shipping in Continental US.
Pictures Here
2ndeffort
