scottajemd
- Joined
- Aug 25, 2008
- Posts
- 7
- Reaction score
- 0
I hope someone can help out. I am taking delivery of my new LR3 (2008) this next week and this vehicle will replace my Disco 1 as my tow vehicle. What I can't seem to find out is some details about the LR3 and towing, the technical stuff.
On my Disco 1 I have an electric brake controller, sway control and weight distributing hitch. Works great.
On the LR3 I am wondering what will be required. I primarily tow a Fleetwood E2 popup camper the weight when we hit the road is about 2500 pounds sometime more depending on the gear load. The E2 is heavy for a popup and the weight can vary 400-600 pounds based on the gear we take.
Electric brakes - Required, this is to much weight to not have them, but I can't seem to determine what is required for the controller. I visited the Land Rover shop manager and he did some research and he found a wiring diagram in the service manuals that shows a brake controller. Everything I read seems to indicate that there is a plug for the controller but no controller. Can anyone clear this up. If I need a controller please post with what has been used.
On the sway control, there is no way to attach this to the factory hardware do I need to find something else. I don't normally need the sway control on my Disco 1 but there are times in a heavy cross wind that it sure makes things better.
Weight distributing hitch - I have read that Land Rover says no on this one comments, thoughts. I use it on my Disco 1 really seems to help with the sag and handling but my understanding is that on the LR3 the air leveling is all that is necessary.
Thanks
Thanks
