Go Back   Land Rover and Range Rover Forums > Technical Discussions > LR3
Sponsored Ads
Register or log in to remove these ads.
LR3 technical discussions for the LR3
Reply
Thread Tools
Old 06-11-2010, 03:45 PM   #1
Rogo
Rogo's Avatar
Brake Bleeding
Has anyone bled their brakes?
Anyone have experience with the Castrol GTLMA that Atlantic British sells?
How much fluid capacity does the brake system have?
Thanks!
__________________
Rogo
2005 LR3
2002 Discovery II
Rogo is offline   Reply With Quote
Old 06-11-2010, 11:13 PM   #2
kwlr3
I just bled my brakes at 75,000 miles and used the Castrol LMA. The pedal was firmer afterwards. It doesn't take much fluid, the quart of LMA is enough to do 3 or 4 vehicles. The whole thing can be done without taking off the wheels, just raise the suspension.
kwlr3 is offline   Reply With Quote
Old 06-12-2010, 08:38 AM   #3
Disco Mike's Avatar
Now to give you a little more accurate information.
Yes that fluid is good, but no since paying that much plus freight when you can buy Vavoline's synthetic DOT 3/4 at your local parts store for less and no shipping. You need 2 quarts cause you don't want to just go thru the motions of changing a little fluid but do it right which will "ALWAYS" take at least 3 plus pints to bleed each wheel till the fluid coming out is crystal clear starting with the r/r then the l/r, r/f the l/f.
If you don't use that much fluid and don't follow the proper sequence you ar just wasting your time.
__________________
Mike
I am a retired service manager of 30 years, currently driving a 99 D2 with the following mods.
Custom made front and rear bumpers, Warn 9500 HSI with 3/8th's rope, sliders, QT diff. guards, electronic CDL, 4:11 gears, rear Detroit with HD axles, Front T.T., HID head light conversions and 3 extra bumper mounted HIDs.
To download the RAVE manual, follow this link http://www.landroverresource.com/
Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm
Disco Mike is offline   Reply With Quote
Old 06-12-2010, 11:29 PM   #4
Mhaise57
Mhaise57's Avatar
Correct me if I am wrong, but I am pretty sure that the LR3's breaking system is quite a bit different from the D1 and D2.
Mhaise57 is offline   Reply With Quote
Old 06-13-2010, 07:15 AM   #5
e24kgold
it is quite a bit different. Once again Mike is polluting the LR3 forum Mike the discovery forum called, you're due back by 5...
e24kgold is offline   Reply With Quote
Old 06-14-2010, 10:25 AM   #6
Rogo
Rogo's Avatar
Mike, please be careful what forum you are posting in. This is not the first time - I would hate for misinformation to live on this forum for someone to stumble upon later. I cannot confirm that the Valvoline meets the LR3 specs. I went to a local auto parts store and it did not specify ISO 4925 class 6. The Castrol meets this spec.
In terms of paying for shipping - I am getting my rotors at the local dealership for a good price with our club discount. It beats shipping those heavy items any day. I will investigate costs for the LR branded brake fluid versus the Castrol shipped.
__________________
Rogo
2005 LR3
2002 Discovery II
Old 06-14-2010, 10:35 AM   #7
Disco Mike's Avatar
Well, I am getting jumped on before any of you have read the spec.s of both the Vavoline and Castrol system synthetic DOT 3 or 4 fluids.
Hers is what I just pulled of line for Castrol,
"Perfect size for topping off your brake fluid level! (12 oz.)
Provides Superior Synthetic Lubrication for Anti-Lock Braking Systems (ABS).
Recommended for all U.S. and foreign vehicles with DOT 3 and DOT 4 requirements, including Land Rover and BMW.
Exceeds DOT 3 and DOT 4 requirements.
Unique Low Moisture Activity (LMA) formulation provides maximum protection against vapor lock brake failure.
Synthetic formulation maintains a higher boiling point than conventional brake fluids.
Superior protection against chloride and zinc corrosion of braking system parts.
Ideally suited for Land Rover and BMW / MINI Cooper vehicles as well as Audi, Jaguar, Mercedes-Benz, Porsche, Saab, Volkswagen, Volvo, Honda, Acura, and many other brake systems.
Exceeds specifications SAE 1703, SAE 1704, ISO 4925, JIS K2233 and FMVSS No. 116 DOT 3 and DOT 4. "
Same thing as what Vavoline states.
So, let's don't be so quick to try and make someone be wrong.
__________________
Mike
Old 06-14-2010, 10:39 AM   #8
Rogo
Rogo's Avatar
Can you provide a link or a quote from Valvoline specs? Specifically the ISO 4925?
__________________
Rogo
2005 LR3
2002 Discovery II
Old 06-14-2010, 10:51 AM   #9
Mr.BigsLR3
Wow. I have never seen a more pathetic bunch. Uh folks...if the fluid meets the OE DOT requirements, the ability to resist water, and temps, then it is fine.
Braking (this is how it's spelled BTW), systems are generally the same basic ABS assisted hydraulic systems that have been in use in the auto industry for the past few decades. In my Porsches, I would regularly (and on purpose) swap the existing OE fluid with one with a better temp rating. Mostly for on-track conditions and high spirited fun.
It is not the braking system that is the compatibility problem, it's the fluids IN the system. Meaning - The fluid MUST be consistent in the whole system for it to work properly. Many fluids have different temp and moisture ratings. This means, never mix different brand fluids. Not all fluids are compatible with each other. Example - Motul 600 has a much higher temp rating and material compound than ATE Super Gold. The Motul will also attract more moisture than the ATE. as a result we were required to flush the Motul system more often.
Simply put - if you have the Castrol in the system, and the fluid is ok, do a bleed with the Castrol. If your rig is ready for a full flush, do what you like as long as it is a complete flush with the correct fluid rated for your vehicle (DOT and TEMP).
Please...enough with the BS.
With regards to Mike, the guy is a 30+ year service expert. I am damn sure he knows more than most about what works and what does not.
__________________
Car junkie - Design Guru - Tool nut
Current Loves:
2007 Land Rover LR3 SE7 - Java Black
Nissan Murano (hers)
Mr.BigsLR3 is offline   Reply With Quote
Old 06-14-2010, 12:01 PM   #10
Rogo
Rogo's Avatar
I have a friend who owns his own shop. He's been in business for 20 years. I have taken cars to him for a long time and trust him explicitly to do work on my cars. But I will not have him work on my Land Rovers. Aside from the fact that I enjoy working on my trucks, he doesn't know jack about them.
Mike's 30 years of experience is invaluable and I don't want to disparage. However, his experience with the LR3 is very limited. It is significantly different from a D1 or a D2. I know. I've worked on both. I won't say for a minute that I know as much as Mike does, but I know enough to say that the D2 and LR3 are very different.
That being said - this isn't BS. Can you tell me what the ISO 4925 spec says and why its acceptable to ignore it?
__________________
Rogo
2005 LR3
2002 Discovery II
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Sponsor Ads
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
Fully Driven Auto Network
GM Truck Forum
Chevy Tahoe Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Tahoe Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Ford Raptor Forum
Scion FR-S Forum
Softball Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
