Please help discovery missing
S18onr
Bought a 51 plate td5 I've changed the injector loom and filter and seals and it's still missing at low revs it only had a little oil in the red plug none in the ecu itself at all I'm really at my end with it now
I'll link a video but don't know if it will work as the attach file won't
Any help is much appreciated
Thanks
http://youtu.be/Uk5QD8-SV7E
have you done a compression test of the cylinders? It sounds to me like you may have one cylinder that isn't even firing. I can only assume you have had all the injectors tested.
S18onr
No I haven't had them tested as I thaught the ecu would have told me if one was knackered
I'm stumped as its ok at high revs
Hight revs then could be a clogged injector. I would take them and have them cleaned.
A562NV
