Buying Pre-owned Range Rover Warranty - MaxCare or Extended LR warranty
bharatkc
Thanks in advance for your responses. I am in the process of buying a pre-owned Range Rover from CarMax.
The RR is under factory warranty and I want your advice on buying MaxCare or extending the warranty provided by Land Rover.
The factory warranty is cheaper but what's the better option. Should I buy the extended Land Rover warranty or buy MaxCare?
Extended warranties are like insurance, each varies a lot between sellers and what they cover. Basically Read what they don't cover and determine if it is truly worth it. Also for the cost of the warranty, would you be better off putting that amount in the bank and saving for a rainy day?
How long do you plan to keep the Rover? How long do you normally keep vehicles?
bharatkc
Thanks Joey ! I am probably going to keep it for 3 - 5 years. I keep hearing that LR warranties are highly recommended, given that any issue can cost in thousands of dollars. Kind of like medical insurance.
I have owned 2 Rovers and currently a Jaguar, so pretty much the same. No extended warranty on any of them for me. Of course I may be the exception, since I do most of my own work on them.
sawcut
