2005 RR hse cant remove key without resetting battery
jlarge89
So everything else in the vehicle is working properly but I cannot remove the key and put it back in without having to reset the battery. So physically the key comes out but when you put it back in the ignition it will not turn, then I have to leave the key in the ignition reset the battery and it turns over no problem. Any suggestions out there??
Have your battery tested.
